there is a brass screw in the top of the carb youll probrobly have to take the muffler off to get to it but its easier than pulling the carb. But its a jet and on mine that often gets clogged up and id say its a good bet thats youre problem. i just pull it out and spray it clear and its good to go
I only see the idler screw and a screw all the way at the bottom (not under) by the valve cover.
Also where is the jet on these carbs, I've never taken one apart?
its on the carb directly under the idle screw. you actually have to screw it in or take it out to get to the jet. If you see nothing there than it may be a different model I dont know about
