A scratch for Rocket Mans itch
KB2ROCKET
Does it run? Does it have gear reduction? What size is that PTO stub is that a hole through it can I get a better picture of the shaft?
Neck
Growing up is optional
The carb is missing the idle air mixture screw so as it sits, probably not. But it has great compression and spark. No gear reduction, the cover you see with the four bolts is a governor housing, and the shaft size is 3/4. The housing could be removed exposing more length on the output shaft, although I think it has a slightly larger step to it. That is not a hole you see, its just been shallow drilled for what I'm assuming was a set screw.
This is the only other pic I have right now.
Oh yeah I have since discarded the tank, it was junk.
