As most of you know I picked up this ARCO EZ Rider yesterday. I took it apart to get it bead blasted (to see what I really have) and I have a Question.
What is the upper hole for on the rear wheel mount (there is one on the other side same location). Is it for other wheel size options,or does something bolt there. The spot where it the wheel is mounted now is worn pretty thin (looks like the axle nut was snugged down to tight without washers between the frame and the hub) could I mount the tire back in the upper location. And are there aftermarket replacement fenders and brackets for these bikes or should I try to find an original
