baja doodle bug engine problem
kidgambit
so i bought a baja doodle bug of craiglist. It sat for a year. when the dude i got it from tried to start it but wouldnt start. so i got it cheap. when i got it home gas smelt like turpintine so i drained the tank and flushed the tank and changed the plug and took apart the carb and cleaned it. and flushed the fuel line. so after all that it wont start. its getting fuel to the carb bowl and spark. i shot some carb cleaner through the spark plug hole and it ignites. i ran out of ideas. please help
gbabins1
A small flathead screwdriver will remove the main jet, just be careful. .. They are brass and pretty soft so be gentle. After you remove the main jet there is an emulsion tube that is behind the main, it's probably clogged as well. That one will usually come out by just tapping the carb lightly.
