i just installed one of these on my warrior;
Torque Converter for #35 Chain, 3/4" Bore (TAV2 Replacement): Go Karts Parts: Racing Kart Parts: Engines: Frames: Tires: Versailles, Ohio: USA: Indoor Track: Tips: Chassis: Kits: GoKart: Briggs: Yerf Dog: Manco: Comet: Torque
the only difference between mine and this one is the 40/41 chain drive sprocket.
to put it on;
used bolts from kit,space out from engine with "1", 5/16 washer.
remove lower cover mount tab at rear of backing plate.
add washer with keyway groove to inside of 40/41 drive sprocket,then sprocket,then driven clutch assy.,then other washer,tighten nut for free movement in bearings but driven tight on shaft.
use a 3/4 washer behind driver clutch to space out clutch/belt alignment.you'll need a 1/2 inch longer bolt for the end of the crankshaft.
remove left side of rear wheel spacer and install 1 1/4 inches of spacers on that side,add 5/8 washer on right side.
install chain,tighten/align chain.
install torque convertor cover,fire the engine up and go riding.
recheck chain tension after first ride.
i will be removing the 40/41 chain and drive sprockets and replacing with 35 drive sprockets and chain.theres more sprockets available for them.you'll most likely need to install the yellow driven spring or at least move the spring to the last hole.my convertor seems to override and go into overdrive per say too fast.
