Hi, use SAE 30 oil. about 13oz capacity. If you have a skid plate you may want to take it off to change the oil. The oil drain screw is on the gear shifter side. It has a washer on it. Look for the lowest bolt. Its easy to find. Your dipstick is right below where your header pipe connects to the head. That's where you check and fill your oil.
