You should hit up Brad directly ... The valve cover needs the baffle removed and minor clearanceing . if you are running larger than a .275 lift cam the spring pockets need to be cut and widened for heavy springs . but I am not sure what the valve clearance is with milling . Barry young has done a lot of work with these heads as well as ole4 and others sure someone will have answers for you
