So ive been having troubles with my clone recently. Its constantly leaking gas out of the carb. I took it apart and found some dirt in it, cleaned that out. I went to start it and the engine was VERY hard to turn. I figured it needed som oil. When i opened the oil cap, GASOLINE POURED out. I mean, the entire engine was filled with gas. The whole crank case, upto the piston and even ontop of the piston. I let it all drain, about a gallon in total.
What would cause my carb to let gas pou into my engine when not in use?
The float seems to be working when i looked at it.
I have a custom gas tank made of a fire extinguisher mounted under the seat. Is this setup allowing gas to flow to much?
Im going to tear everything down and i suppose in the future ill turn the fuel off when not using it.
