dave
dave he is running a dynocam 245. dynocam recommends a 18 pound spring and for the guys that use a 255 cam it would be a 20 pound spring. isky black mamba cam would be a 26 pound spring and thats coming right from tim isky.
For an OHV engine. Where has he recommended an 18 LB spring for the flat heads? At what RPM is a stock FH spring floating the valves? I'm just asking, because so far no one who has used the stock springs has complained of float.
Isn't a "Black Mamba" one of those bolt on parts for Predators?:laugh:
I can find no instance of anyone commenting on ignition timing with these hotter cams. The only cards I've seen for a flat head was the one Ole4 posted long ago, and there was nothing on it about ignition.
Granted, I have nothing to say here of any import, but the myriad posts on the subject seem to stop short of anything concrete regarding seat tension and ignition settings on FH's, and in every other four cycle application I've worked with, they're vital.
Great information on using the later springs and automotive keepers. I have found deformed keepers (top and bottom) on several HS and H engines upon disassembly, so I agree with you on their viability over sustained higher RPM. I use the same spring compressor you do. :laugh:
Dave yes ATKrider told me about the replacement valves being thinner and Briggs being thicker. I measured up some old and replacement tec valves and he was correct. The Briggs valves are longer so you have to make the retainer grooves. I am running more spring than I need so it will be a durability test if my retainer groove will eventually break.
I recall this conversation, where you offered to let me use your seat tools! :thumbsup: I shied away from it, as I have no lathe. That engine still lives in it's original Cat Wildcat.
I am enjoying this thread, and the work you, Fast Tony, Delray, Rupp 72, Wulf and Markus do with these Tecumseh engines in not only modifying them, but in keeping them alive. (and there are others here whom I am aware of)
