My point was that fuel coming out of the pulse port means the diaphragm is passing fuel. That is why I asked about the Mikuni pump, as I was wondering if he was over-pressurizing the diaphragm with it and causing the fuel by pass, or he has a leak in the diaphragm.
Since he has the engine running, I assume the Mikuni pump is doing the pumping, not the carb. So what pop off pressure should he set for the Briggs on gasoline?
[MENTION=23480]madzx2[/MENTION] this is the throttle cable mount plate and Tilly throttle arm I was referring to. Not a Briggs, but the same application. [MENTION=31879]CarPlayLB[/MENTION] knows where to get these parts, if you don't have the tiller.
(photo is a clone Tilly, but same application)
