Background: I got the motor running, but cycled the kill switch a bunch of times to keep it from overspeeding while attempting to adjust idle down. Engine died, wouldn't restart, no spark. I assumed I'd fried the coil by cycling kill switch. (No points/condensor)
Ordered replacement coil, adjusted flywheel gap to .010 and still no spark. Verified spark plug as good with another motor. Kill switch wire disconnected.
I checked continuity from the kill wire tab on the coil to ground. It is grounded via the case of the coil mount with no wire on it. Both coils are like that. I thought the act of grounding that tab via kill switch was what caused the coil to stop making spark.
Am I missing something here? Am I supposed to cut whatever piece of copper is shorting the tab to the coil frame to electrically isolate it? Such a simple system, but it's kicking my ass. Thanks in advance for any enlightment on the subject.
