Briggs flat head 5hp tank question.
125ccCrazy
what about some JB weld gas tank epoxy, smear it around to fill the holes and after it sets up use Caswell or Redcote sealer..
It that the new or old style tank? Which carb does it carry?
I'm not 100% on which carb it uses. I've gotta go look. I bought the setup used. From what I found it was the more common carb (doubt that helps tho). I've got the rebuild kit so I can pull the numbers and that might help.
Yep newer style of carb, but still a pulsa. Looking at your tank, I'd just get a replacement tank. I saw a couple on Ebay this morning. One of them was the deep tank your carb is set up for. It was pretty reasonable.
