My Linkage
This is my 5 HP Briggs, But it should give you an Idea. Most of the carbs have a cable mount on the rear of the carb. If your does then you can hook it up just like this. Or you can use a Briggs Raptor Racing throttle bell crank set up. There the way to go if you have the clearance.
