Hi,
I have started making a frame for a minibike. The rear wheel is a 15" diameter (395mm), has a 70 tooth sprocket on it #428 pitch and size chain.
The engine I have is a 3hp briggs.
What gear ratio would I need for hill climbing and going slower for the kids?
I can get a 12 tooth #428 centrifugal clutch that will match my 70 rear wheel, which will give me. 5.83 ratio. I feel this is to tall and the clutch will get burned out quickly.
So what to do?? I could make a jackshaft setup.
I have got a 9 tooth sprocket that matches the 70 tooth rear sprocket and a 1" shaft and bearings. These parts came off a ride on mower.
So 70T rear into the 9T jackshaft output = 7.77 to 1.
Then I can purchase a clutch, chain and an input sprocket for the jackshaft. These can be any pitch of chain as it does not matter as long as they are the same.
But my question here is, what overall gear ratio do I need to aim for at the rear sprocket with the 3hp engine?
Also, would a torque converter work properly with a 3hp engine?
Peter
Peter
