Hi everyone. I love all of the info I have gotten from this site so far. But with all the reading I have done I am still somewhat baffled on a few things. Before i start with the questions. however, I want to let you know what I want and what I'm doing. I have a brand new HF-6.5c engine with maybe 5 minutes of burn time on it. This engine will be going on an older model box frame go-kart. I want to beef it up some before I run it though because; one, I like speed and two, I have read posts on other forums where people have blown the engine and blamed it on a bad valve train. Now for the questions:
1) Would replacing the stock cam with a CL1 cam be beneficial in anyway?As to the longevity or performance of the engine? I don't want to go crazy with this motor, just want it to run great and sound good too. (More on this below)
2) I have read about the 1-1.3 ratio rockers and was wondering if i should get a set? Would they work with the stock or CL1 cam with no hassles?
3) I am already planning on replacing the stock springs with 26lb springs since every forum you goto recommends it. Especially since I will be going billet on the rod and fly-wheel (yup after those are in... buh-bye governor ). What other recommendations do you guys have for the valve train to increase longevity and slight performance boost?
Back to the cam question, if the only difference between stock and the CL1 is the hardened contact surface, what would you recommend for a cam for this motor build? (please give links! I plan to be buying from NR-Racing). I would like to have the motor revving about 6500-7000 after all the work is done.
MANY thanks for reading this and double thanks to those who provide input.
Kyle
Kyle
