Champion rocker install ????
When installing these rockers do they need spacers under the pedestal ? After doing searches on here seem like some put washers under the pedestal . Is this needed ?
rmm727
you basically want the center of the rocker arm tip to stay in the center of the valve stem/lash cap throughout its range of travel
you will know when you try to set valve lash. you will run out of rocker tip. if the rocker tip spins so far into arm that you hit valve with the arm instead of tip. If you have a milled head you may need to shim.
