I think if I was trying to make my money go far with the BSP motor I would order it with the billet flywheel for and extra $75, swap springs for 22 LB, add ratio rockers, keep the BSP 4 cam it comes with but replace the lifters with stock weight lifters, add a billet rod and a flat top piston to the motor. The carb is already jetted so I would just leave it alone. Next BSP I tare apart I am checking valve seal because my valves had no marks from being lapped. I don't know if they ever sealed though as I used the valves or tried to in another head. (Found out the UT2 head had a 23mm exhaust not a 24mm)
