I received my Harbor Freight 6.5 today and mocked up the clutch on it.
When pushed all the way down, there is a slight gap of where the bolt will go. The clutch will be able to slide back and forth on the driveshaft.
Is this normal?
Should I put a washer behind the clutch so it is even with the end of the driveshaft?
Also, what is the thread/pitch bolt to use?
Is this normal?
