A friend of mine wanted to be able to mount a nice brake caliper on his project... and ran into an issue with the typical hub for the common universal brake rotor interfering with caliper mount and bolts...
there were many different ways to address this issue, but since he is building a very very nice mini bike, I figured I would add a touch to the resolution...
I asked him to send me a pic of his wheel (front, as this is a live axle bike with a solid rear wheel)... this is the vintage wheel he is using...
this is what I programmed and laser cut for his project...
while at it, I figured I would make a couple of wave rotors to match the Astro style wheels, I like so much... I will more than likely have these coated... I have also programmed the astros to work with the available hub and a bolt on... but I am going to weld the hubs on these, so that there are no bolts and they are as "clean" as possible... 3/16" thick and 7.1" OD... 1" live axle
