It's best to use a honing tool that's a proper fit for the cylinder. As mentioned above, unless the cylinder is really bad you should be able to hone it and just install a new set of stock bore rings. Also clean up+ re-seat your valves while your at it.
If the cylinder is bad, your prob going to have to send it out and have it bored .
Vic
