Hey everyone. I recently raced a buddy on my modified briggs 5 hp flathead, and have been kind of bummed that the engine doesnt break 3800 rpms on a flat surface. Here is some background (before you ask 'did you remove the governor?') :thumbsup:
Briggs5 hp flathead with steel sleeve i built from the ground up. dual bearing block, 94ss cam, stock billet conrod, 19 lb springs (as cam card indacated, also set lash to card specs), indexed plug, billet flywheel, lapped valves, broken in now with 10 hours runtime on it. Has 1" thin stainless exhaust (~.87" ID), and a 1" 'race' muffler (i forget the name of it)... basically engine is in great shape.
I feel like (as another member said before here) that the torque converter is limiting the rpms, where i should be reaching 6k+ rpms, im only getting 3800 before it planes out. I was driving downhill slightly and it slowly (and i mean slowly) eventually got to 4300 rpms.
So i eventually am going to have to race my friend again and I want to school him in the race. (I beat him off the line, but he catches up and beats me at the end). i have an 8t on the jackshaft and a 50 (stock?) sprocket on the axle. baja mini bike -the one in my avatar
Is there any hope with the 30 series of going into the 5k rpms? I also have a cheetah clutch and am considering using that with a gear reducer (13, 14, or 15 on the clutch the clutch lets you swap) 20 on jackshaft in, 8t jackshaft out 50t axle, and 19" tires.
Thoughts?
Thoughts?
