The local drags are coming up and just wondering what you guys would run for gear/clutch package.
The drag is 100 feet long. I will be in modified division. HEMI, ROD, FLYWHEEL, MOD2 CHEATA CAM, 18 LB SPRINGS, UNI FILTER, HEADER, #38 JET WITH TUBE
I just ordered a hilliard inferno clutch 12 tooth and have an 80 tooth 2 piece rear sprocket with 13 inch tires. the cheap stock clutch grabs to early and i want to match clutch engagement when the engine starts making its power.
with my set up, at what RPM should be good to set the clutch engagement? i don't have a tach
thanks todd
thanks todd
