I've spent days reading and researching on what motor I have I still don't know for sure.
I've came to the conclusion that I should just open it up and go from there.
Specs I know about Engine :
on a Baja warrior mb200 minibike. Dealer said its a rato r200 which indeed it is stamped on block along with engine serial num.
Dealer said it was a predator style. Punching in engine specs led me to other engines with jf200 names.
I first thought I had an old predator. Then I thought I had a gx200 clone because of jf200 findings.
Here are specs from manual
bore and stroke = 2.68 x 2.13 inches (68 x 54.1 mm)
displacement = 196cc
compression ratio = 8:5:1
valve clearance = IN: 0.15 +- 0.02 mm
EX: 0.20 +- 0.02 mm
Ignition = TCI
Spark Plug = NGK BP6ES
So once I open this up how will I tell what I have ? Measure cam ? Crankshaft?
My goal as of now is to swap out the cam, springs, rod, flywheel, adjust timing, add header and muff, add air intake, bore carb, and add tav2-30
Don't know what section to order from due to confusion (old predator, new predator, Honda clone ???? )
Thanks for some help !!
EX: 0.20 +- 0.02 mm
Ignition = TCI
