Looking for help as to what is causing this and how to correct it...
The carb has a leak at the mixture adjustment screw on the bottom of the bowl. It is a VERY slow leak, more like a seepage, really. To be clear, it is NOT coming from the nut/gasket at the bottom of the float bowl. It is running down the shaft of the screw itself, apparently where the screw penetrates/passes through the bowl nut.
Background: The carb WAS recently removed (bowl was completely drained of fuel), for engine painting, however no individual carb parts were removed and no screws were removed or adjusted during the process. The carb did not leak before it was removed, however, it started to leak at the screw once it was reinstalled and the engine was "test ran" for a short while. Coincidence? Or is there some internal gasket/seal that may have dried out or shrunk after the fuel was removed?
Thanks for any help!
[/IMG]
