if your tank is lower than the carb you will need a fuel pump. otherwise you are better off with gravity feed. A lot of carbs are designed to be gravity fed. If you use a fuel pump it may have enough pressure to push open the needle/seat and flood the carb. Mikuni have some small needle seat sets to allow fuel pump operation.
