Fellas, I don't think I'm getting a strong enough pulse to power the fuel pump. I'm running the pulse fitting off the manifold after the carburetor. Since this is a marine application, I have a bulb on a true marine gas tank. Once I prime the carburetor bowl full of fuel, it will run for about a minute or so the die. I'm guessing no gas is being pumped. I'm running a NR 230 cam, so I figure that wouldn't be too much camshaft, but I still don't think I'm getting a strong signal.
Do you get a stronger signal off the valve cover?
