I saw this on Ebay-it looks like a better carb to use for my Taco Two Stroke. I noticed it has the idle speed screw,of course,but what are the two other screws for? Does this carb have two mixture adjustments? Thanks for any info.
You were the fellow asking about carbs as I recall...
Well you seem to have what you need now.
Do a complete strip down and cleaning ( I use oven cleaner on these then a wash and Wire wool every inch.....
Then I clean the screws and polish the tips....
I tin the throttle shaft to take up wear.
You will need a skin kit for sure but I would spring for the complete rebuild.
I would be inclined to strip the chock out and use the primer feature.
Alternatives to this carb are hard to find...
