I'm wanting to get the honda flat top piston with the +.75mm bore and was wondering if it will make that much of a difference if I go with that size. I know I'll have to get it bored and might as well get it decked. Will the bigger piston work with the STD length billet rod? And what gains can I expect? Also any other advice is appreciated
Mods -gx160
header
air filter
.41 jet(stock carb)
billet rod
.265 Dyno cam
ported head
18lb valve springs
running e85
I've posted my mods before but just a refresh.
thank you
SJ
Mods -gx160
header
air filter
.41 jet(stock carb)
billet rod
.265 Dyno cam
ported head
18lb valve springs
running e85
thank you
SJ
