This is what I was thinking about running
24mm mikuni
Billet rod
Billet fly wheel
Flat top piston
Cam I'm going to need hell with anyone know what cam I should run
Custom stage 3 f&b header
And can some one tell me which head I should use and what to do to it
Also what springs and rockers
Just a little faster on a tight budget is hard to do.
Cheapest things first.
Champion rockers ( or a step bellow are Honda but both of these are better than stock.
Cam Tim Isky makes lot of good cams that are not expensive.
Alternative Burris racing can sell you some Yahmaha rockers ( so can the Yamaha dealer in your area )
No money for Billet?
Nonsence there are Steel billet and very inexpensive alternatives like the PLV entry level PLV and although some disaprove the Honda GXV 160 lawn mower flywheel is extremely strong.
Valves and stock clone parts could and should be upgraded at least to Honda parts.
Springs depend on cam
Carbs what ever floats your boat....
But you have a stock valve head so nothing bigger than 22mm will help you.( no one listens anyways so run what ever makes you happy, I strongly sugest you avoid large tillotsons and slide carbs )
Piston use the Z4M Honda.
File fit an over size top ring for .005 no tighter !!!
This is bumping up against the limits for tightness I mean it no tighter....
I would sugest you measure now with your stock rod and the flat top piston you order and then run a longer than stock rod since most clones are in the hole already.
There are plenty of aftermarket head gaskets to help you get your quench around .030.
I like the 14cc head its a great torquy little head with lots of potential.
Porting
polishing keep it is conservative, just knock the edges off the ports and make things smooth not bigger ( much info on porting here just read ).
