Hello all,
I have a HT35 aspera motor which is pretty much the same as a H35 Tecumseh. I am rebuilding it and with new valves installed, the valve clearances are .014 and .028 for intake and exhaust, repectively.
I know the clearances should be .004 and .008 as per spec and I know to grind the valve stems when the valve clearances are too tight but how do you remove excessive clearance?
Can I get longer lifters? Do I need to weld a little bit on to lengthen a valve or lifter?
Any help would be appreciated.
Mailman
Mailman
