I bought a H50 Light coil and flywheel from and OldMiniBikes member to convert my non-lighted coil H50 into a H50 w/light coil.
Prior to install the H50 ran perfect and I heard after you remove a magneto it's very heard to get back into correct position. But I still thought what the heck I will give it a try.
Well! I installed and guess what it doesn't start. Just my luck. Anyway, not sure why.
I have the following.... compression, great spark and carb is adjusted correctly and getting gas. So what do I have wrong? Please help.
My old coil had a black ground wire running from Magneto to block. I didn't install on new set-up because I planned to ground through light switch, like the Rupps.
If I don't have magneto grounded to block and don't have a ground currently installed on wire harness should the motor still fire?
Or is that possible my problem? Any ideas would be great. I already search and got scared off by other peoples stories of problems with same thing. Any help would be great.
