Damn Dave, I only understood about 1/2 of what your saying .. your one smart SOB!
Expect a PM if I have issues sorting the VT out ... :bowdown:
Not so smart. I hope I answered your question concerning the two outputs. The parameters on the smaller flywheels and the limited space dictated small amperage alternators. Six amps for two lamps required two alternators, commonly referred to as "lighting coils."
The bulk of my techno-babble was directed at Ole's comment that one could wire both of these outputs to a single input on a full wave rectifier.
sounds like you are describing it shows one wire going to head and tail light and the other going to a stop lamp with no diodes used.
Yes sir, that is the one he has. We've seen numerous questions here regarding methods to provide battery charging/LED lamp usage with these smaller systems. You're right, there were several permutations of Tecumseh alternators out there for the various applications. This does lead to some confusion, as some of them even had both DC and AC outputs, and DC motor-generators.
So my earlier comment was about applying both leads of this system to a common input on that e-bay fullwave rectifier.
The only way to isolate out of phase legs on either coil is to wire each output to a separate anode for half wave, with positive pulsating DC paralleled on a bus for the charging system.
Given that 1.1 ohm impedance, and -10VAC to +10VAC cycle, a current will exist on the coils before a load is ever applied, and power input will always be something less than 10VAC. That is why I questioned your comment, although it is valid with the other Tec alternators out there.
A thread on 3amp coil rectification.
I didn't mean to muck up the thread. MB165 did a lot of testing on this particular coil in an attempt to convert both coils into a single one so he could use it as a single power source. He could not, for the reasons stated. I wish I could find that thread.
Also, in a previous thread, I stated these were in series. I was wrong. They are two separate units, and become parallel when the outputs are wired together. (Just before they melt) On the other hand, I would be very interested to see someone risk that $100 replacement cost, and wire these two outputs together, and measure total output, as well as amperage. Not me. Someone else interested in debunking my version of Ohm's Law, LOL. :laugh:
