30 plus years ago I bought a used rental big wheel mower made by Maxim. The ID sticker's ink is long gone. There is a serial number?? stamped into the foil sticker.
90-524BICS2-03. No other numbers are on this mower that I can find.
The engine is a B&S and the pull starter/cooling housing is not original to the engine. There are no numbers stamped on it anyway.
I 'think' the engine is a 5 HP,not sure. I've checked every inch of the engine and cannot find any markings. Many layers of paint on the block.
I was cutting the weeds with this mower and it was running just fine. I keep my stuff up on oil changes and spark gap,coil clean,etc. I shut it down to use the weed whacker and when I went to start it,no go. There seems to be a spark but it looks weak to me. Sometimes white,sometimes yellow. Changed plug,no go. Removed stop wire,no go. Starter fluid,no go. Starter fluid right into the spark plug hole,no go. Not even a back fire. Compression seems normal,good suction on the intake manifold.
So I'm assuming ( yea I know) the ignition coil is just no good. I replaced the pull starter after it broke trying to start the engine.
Please if you can help me ID this engine so I can buy a new or used ignition coil I'd be very appreciative. Fixed income and all that.
