Guy/Gals, I have a Ruttman that I'm trying to figure out what's what. I got it years ago as a roller of sorts. I stripped and paintd it, added the requisite power, rear wheel, tires etc. then stiched up a seat.
It has flip up foot pegs and the kickstand is mounted to the frame tube with a small bracket like my Taco has, not under the motor plate like the 60's models. No Jackshaft or springs of any kind and it either has the wrong forks or the front tube was cut then "fixed". I measure 6" on the fork where the pivot bolt goes and as can be seen in one pic, there is an obvious piece that has been welded to the top of the frame pivot. It also has bends on the lower fork triple tree to clear the frame when turned full lock.
Any info would be great.
Todd
Todd
