Hello everyone, this is my first post..
I recently built a 212 Predator with the Hemi head and need some help tuning
Here is what I did to the build-
Removed the govoner
Removed the low oil Spenser
Installed air filter and adapter
Minibike header
18lb valve springs
Racing spark plug
ARC RuiXing carburetor
GX 140 E tube
.038 main jet
.022 idle jet
Top plate and fuel pump
Before anybody starts bashing I'm not finished yet, I'm planning on getting a conrod and flywheel before I start riding, I'm just trying to tune what I got
Anyway my jets are not right.. I get a lot of backfire when it comes off idle. It's hard to get a plug reading when the motor isn't mounted on anything( but the plug looks good). The motor seems to be running too hot, I think that's a sign of being too lean.
With that new carb should my jets be larger? Also I hooked up a cheap RPM meter and its reading almost 2500 on idle, seems too high, when I idle it down it wants to cut off.
Any help on my set up would be appreciated.
Removed the govoner
Minibike header
18lb valve springs
Racing spark plug
GX 140 E tube
.038 main jet
.022 idle jet
