The mower is a Craftsman YS4500 46" cut.
I just got it.
The belt that came on it worked but was a bit grabby when you lifted the brake pedal and engaged the belt.
It is likely the belt it was sold with.
I bought a new belt off amazon https://www.amazon.com/gp/product/B01AGQ3VZI/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
The numbers match and I looked it over and it is the same diameter with the same cross section, its identical visually.
When installed its grabby as hell, once its in gear you cant get it out of gear. It creeps along ...
Its smoking a little too.
It is installed correctly with no binding (there is a diagram to follow) and with the pedal pushed down there is plenty of slack in the belt as there should be.
I had my brother Tom (Beekeeper) double check it and its installed correctly.
The pulley on the motor is clean and not bent.
The Craftsman belt is Black and about $56 https://www.searspartsdirect.com/part-number/194346/0071/917.html?modelNumber=917287230&categoryName=Lawn,%20Tractor&brandName=CRAFTSMAN
Did I make a mistake trying to save some $$ and not buying a Genuing Craftsman Belt?
I just got it.
