Guys,
I just built this engine and did a few upgrades. Governor removed,Billet flywheel with 8 degree timing advance built in, arc billet rod stock length, and a stage 1 kit with air filter,jets,emulsion tube, exhaust. When I start the engine it starts fine and runs well at low power. Once I start revving it up to about half throttle it starts to hit what sounds like a rev limiter and backs itself down. If I power through it, it does the same thing. Am I getting valve float with the stock 18lb springs? Should I go to 26lbs? The plug looks a little lean as well. Any help would be appreciated. This is the first time I have done more than just a stage 1 kit. I build cars typically,but I'm stuck on this one. I attached a video to show what I am talking about. Thank you [video=youtube_share;_h7kaStCL38]https://youtu.be/_h7kaStCL38[/video]
