Hey guys, first time using the forum basically i have an old kt100 kart frame that needed an engine. So i went to harbor freight yesterday to pick up a 212 to build. They only had the 730 models everywhere untill i saw a random engine out of the box just sitting under a shelf. I asked a worker and he said it was a return and he would sell it for 80 dollars. Hell ya! It was also the hemi model and at the register they only charged me 60 dollars so i scored. The cylinder was hydrolocked with old gas which is why someone returned it im guessing. That took about 2 seconds to fix now she starts first pull.
Anyways... Im tryng to build this motor to bash around my backyard and around the street so i need to keep it on the cheap side. I think im going to use the black mamba jr cam, which is good for like 6k correct? Also i was going to use a billet rod, stock flywheel with 4 degree advance. What pipe and intake would u guys recomend for good power with nice torque? Also i heard u cant use aftermarket rockers on the hemi head. Should i use a higher lift cam then? Also will a stock maxtorque clutch be good enough? Im confused so i would appreciate if u guys helped me out thanks!
