I usually try to figure out these problems myself, but after 2 days of working on this problem I am stumped.
I have a early 70's HS-40 that was rebuilt around 7 years ago but never started. I changed the oil, checked for spark and put some fresh gas in it and nothing. Found the timing was a bit off so while I had it apart I checked the points and now it fires but only runs for about 10 seconds and dies.
It always fires right back up on the first pull, idles nice then dies again. If you try to give it any throttle it dies right away. I even pulled the carb off my old snowblower that runs great and it does the same.
I have also replaced the fuel line , Checked the float level on both carbs .
Any ideas what to check next? I might pull the whole ignition off the running motor and try that but for some reason I keep thinking its fuel related.
