I spent some today trying to get my HS40 up and running. I could it to run at pull choke but nothing I did get get it torun past full choke. After doing some reading I sprayed carb cleaner around different parts of the carb while the engine was running. Lo and behold, the throttle shaft seems like its leaking air.
Thanks
- Is there anying worth doing to fix this?
- Are the chinese carbs on ebay any good, and other than the adjustment on the bottom is there anything else to look out for?
- Are the carbs for the H30 and HS40 different?
Thanks
