HS50-67023 Crank Case Cover Oil seal removal
Anyone have some advice on removal of the Crankcase Cover oil seal on an HS50. I dont want to do any damage to the crank shaft. Trying to get the case cover off to do a rebuild. HS50.JPG
safest way is to drill 2 holes in seal across from each other and run some small metal screws into the holes to pry from.
That worked awsome...thx so much
Glad that it helped you. So many others over the years have asked the same question that you did (or got into trouble because they did not!) so I asked the forum moderators (twice!) to make it a "sticky" after I first posted my son's photos. Still no sticky - I guess it is not worthy?
Michael
