if you put in a new o ring and washer, I doubt its leaking from the jet screw. Did you change the washer under the bowl nut? if not it could be coming from there. How about the larger O-Ring, the one that seals the bowl? if that one is old or is even sitting in there wrong, it's gonna leak....it shouldn't be too big either, you should have to strech it a little over the lip it sits on! Then sort of push and twist the bowl back over the O-ring until it stops. If you have it on right, the bowl will sit on there without the screw even being on! it should be a tight seal! good luck, hopefully you'll find it quick.
