I've checked through a bunch of threads here and still can't get this thing running. It's a newer model HS50 without points. It has been sitting outside for a while and the carb was seized up. It had good compression and spark, so I figured I could just throw another carb on and it would fire right up. Wrong! Tried spraying starter fluid in and it won't fire. Pulled off the side cover and cleaned off the coil and flywheel magnets. Still no go. Read about someone having a sheared off flywheel key, so I took it apart and it was fine. I can't figure out how I can get plenty of spark, but this thing still won't fire. Any other ideas?
