Just got started with the rebuild of a DB I picked up on craigslist. I paid too much for it but I've never really been screwed by CL before so I guess this is my lesson. It runs but barely and with the Predator 212cc engine being so cheap I decided to just go that route, much to my better half's dismay
We do quite a bit of back country exploring with our Toyota FJ Cruiser and off road trailer so I figured this will be perfect mounted on a custom receiver hitch tray on the back of the trailer. I'm not looking to break any records, just have something fun to goof around with when we explore so it will be a mild build compared to some of ya'lls builds.
Plans are as follows:
Predator 212cc conversion
PMR motor plate
PMR jackshaft kit
under seat header with custom support
header wrap
bullet muffler
tuck/roll seat
new OEM grips
using OEM throttle and kill switch
new bearings all around
Kenda Scorpion tires
wheels sandblasted and powder coated matte black
frame/fenders sandblasted and powder coated Toyota Sun Fusion yellow
It will be transported on the back of the trailer (built the frame with a receiver hitch on the back for such things)
Now for some progress pics...
It's not in great running shape but it's complete so that's good.
Stripped down to a roller, little bit of rust and a small bend in the front fender but nothing I can't easily fix.
Jackshaft setup and mounting bracket for the primary chain cover, just test fitting so far, no key in the crank yet.
Got the stock exhaust off and installed the under seat header from HRM, need to weld on the threaded coupler and fab up a support.
Got the throttle cable connected with parts from HRM, not sure my setup is exactly how they envisioned it because I had parts left but it works and is super smooth.
Unifilter installed, breather installed, choke retainer installed and carb rejetted.
Love the difference between the two engines! I always say if something is worth doing, it's worth overdoing
PMR motor plate
PMR jackshaft kit
header wrap
bullet muffler
tuck/roll seat
new OEM grips
