Lighting coil
They flywheels have different tapers and will not seat correctly. Which predator do you have? Hemi or non?
Sent from my Texas Instruments Speak and Spell...[emoji2]
The hemis can run the Kohler lighter flywhee with no mods. The non Hemi would need machining to use a clone or Kohler.
Hemi has the cast aluminum valve cover. A magnet will not stick. Look for part number 60363 at your local harbor freight if you need a Hemi...
Put coils on one of my predator hemi's but had to put a gx200 crank in it so that i could use a honda/clone flywheel with the two magnets in it. Then i had a 208cc engine cause the honda/clone crank has a 1mm shorter stroke than the predator crank. Still run good though.
harbor freight 6.5 motor
I do not live in the USA so I have to ask does HF still have a 196cc clone on the shelf?
Someone probably has a 196 on the shelf that is a direct clone and easy to add the lighting package too.
We have tractor supply up here.
They have clones from Champion and some blue thing I never looked at very closely ( they should change their name to expensive supply )...
