YES!!!! You got lucky as hell on that one...... :bowdown:
That is the vertical shaft 6 horse motor.. VH60....
http://www.oldminibikes.com/forum/tecumseh-engines/58774-tecumseh-6-horse-lighted-system.html
That aluminum lighted flywheel just happens to be the exact same part as the horizontal lighted 5-7 horse motors... So the flywheel is minibike correct parts for like a 69 Bonanza H50 or something..
The coil will work all the same an is ALSO the exact same part, for a horizontal shat electric start motor... Most commonly you would find THESE charging setups in the HH60 cast iron motors, like on a Toro or Troytbilt rototiller... Those motors used a cast iron flywheel...
You DON'T NEED that rectifier panel for the system to work, as the wire running to each one, are both positive DC current out....
But I would recommend using it, as it's there and works like it should... :thumbsup: PLUS it's like Delray said, and you could charge a battery with it, like it's supposed to do..
