Got a question on float bowl tuning with a post pump. First some background info, When i first put this kehin 24mm carb it ran fine i realized that the carb wasnt getting all of the fuel from the pump since the line was too high. So I stuck the fuel line from the pump to the carb lower and that seemed to give the bike alot more fuel and obviously a lot more power(powerwheelies). But ever since i moved the fuel line lower everytime i start the bike, the fuel overflow would just shoot water out. I cant seem to get the float height to be perfect. Either the bike doesnt get enough fuel and either wont start or will bog hard when opening the throttle hard, Or the bike will run fine but dump fuel out of the overflow.
But also a second small question, if i can get the bike to not leak but bog with wot would i have to adjust the throttle needle?
