Hey guys, i got this motor from my grandpa 2 years ago before he passed away. It kinda sat around and i decided to mess with it a few days ago. Found out it needed a carb kit so i went and looked through my motorcycle parts. It just so happened that i had a carb that bolted up to the motor rather than slipping into a rubber boot (like most most motorcycle carbs). The bolt patter was similar but i still had to drill out the holes and file one of them to make it oblonged to fit properly. Also had to put a small piece of sheet metal in there to cover up an open spot on the carb (because the bore on the throttle body was bigger than the bore of the intake port. Turned the choke on... and it roars like a monster. Kinda wondering what kind of motor this is. It came off of a snow blower of some sort and it is 2 stroke. No numbers on anything from what i can see. The carb is off of a Lifan 100cc dirtbike. The transmission on the Lifan took a dump so i pulled all the parts off of it that would be useable
https://www.youtube.com/watch?v=WmwEA5-0wWI
There it is an all of its beastly ness. Let me know what you guys think.
