So last week, a riding mower came back to me. I had gotten it cheap, fixed what was wrong, and made it a working mower. 70's Simplicity Grabber. Like this one:
I have the same one without the catcher. 30" cut, single blade.
After I fixed it, a buddy bought 5 acres and didn't have a mower. He borrowed it and proceeded to beat the snot out of it. Blade is now out of balance, all the bearings toast, 3 flat tires and the motor smoking blue bad last time I saw i running. Since then he also broke the recoil, took off the blower housing and then lost it. Grrr. That is when I decided to take it back.
I have another blower housing, but I don't have a recoil for it. Need one with square drive and 6 3/4" across the mounting bolts. Anyone have a spare?
Yanked the deck off(two bolts and the belt) and already stripped it down. I will be stripping the rest of the mower down soon. All parts to be sandblasted and powdercoated.
So here I am with the deck torn down and the motor torn down but I am not sure what parts to get for the motor. The shroud is now gone, so I don't have a Briggs model number or serial to work with. All I know for sure is 3" bore and 2 3/4" stroke, and the "19"s cast into the head, block, and rod. Coolbore. Amazingly, the bore looks pretty smooth, no ring ridge nor hone marks, but the ring gap is about .077"(over double the .035" reject size in my Briggs manual).
Any ideas where I can find the rings, gaskets, seals, etc, without the model/serial number?
