I know this bs has caused me lots of trouble and money but I have found my problem to my TAV system. It was not something that normally should never happen... I have had all kinds of trouble with my TAV on my go kart eating belts. I had everything rust free and in perfect condition and still my kart kept eating through belts. After asking some questions and floating around ideas to alternatives ( MAJOR FAIL) I was about ready to give up on the TAV. I just bought an entire new driver but I went outside to lubricate It but as I was taking the driver apart I noticed something. The little hub piece in the center was stuck. I had to take a small bolt and put it on the hub and pound it through. I lubricated it and tested it again but it was way too tight. On my other driver it was a tight fit but when lubed it would roughly slide through. I was extremely Angry so i took a file and decided to file down the hole where the little hub slides through. When I bought the unit the hole for the hub was too small, so the engagement was screwed up and it ate through belts. I filed until the hub slid through freely:grind:, I installed back on my go kart and it worked fine. At this point I wanted to slam my neck in the door repeatedly for not noticing that it should slide through freely. It had to be my luck that I received two driver units that the hub holes were too small on. After I fixed my issue I tested it and my belt is a slightly worn belt but it works just fine. I want to apologize for debates with people on this subject but I cant believe that two of my driver units both had the same problem the first one was a comet but the second was one off of ebay. If anyone reads this and gets a new TAV please check everything to avoid problems and a bunch of money spent on nothing.:thumbsup:
